gm#88961867 distributor problem....help
Old Jan 28, 2007 | 06:37 PM
Ramer's Avatar
Car: 1984 Camaro Z28
Engine: 5.7L crate engine
Transmission: 5-spd
Axle/Gears: 7.5 with 3.73
I have purchased a distributor (#88961867) for my new 350 vortec engine (gm#12486041), and am wondering if anyone else who has this same distributor and engine replaced the gear that came with the unit for #10456413 melonized gear? Should I use the gear that came on the distributor (hopefully won't cause any damage) because the melonized gear looks the same but does not even have the metal tooth that engadges with the oil pump shaft.
Thanks for you help
Old Feb 3, 2007 | 12:44 AM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
you need that oil pump slot...
Old Feb 3, 2007 | 09:57 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
The "tooth" that engages the oil pump is an extension on the dist. shaft itself. Take off the old gear and you'll see it. The gear has to match up with the camshaft material. Some roller cams are hardened steel and require the hard gear. Older cams used a softer gear. A mismatched gear will not last long. Some aftermarket camshafts have a pressed on standard gear that works with the softer gears in older dists.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
