install hatch relase??
Old Jan 31, 2007 | 01:20 PM
diablo666mew's Avatar
Car: 89 camaro RS convertible
Engine: 305 tbi
ok i am trying to install a hatch relase in my 1986 camaro with a power pull downi have the switch and the relay from a just car witch where by the pull down in a 87 camaro for the yeard but i dont no if that is aww i nead and how to hook it up?
Old Jan 31, 2007 | 06:17 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
You need switch, relay, solenoid release and ground wire. The solenoid bolts in place of the manual hatch release. The black wire that connects to the solenoid is +12 v from the switch and relay (go figure the logic in using black for positive). You'll need to run a ground wire from the 10mm screw (that attaches the solnoid to the hatch pull-down unit) to the ground location on the body below the pull-down unit. Adding the ground is important because the solenoid is electrically isolated from ground by the nylon guides.
Lon
Old Jan 31, 2007 | 06:28 PM
Engine: 305 tbi
thanx helps alot
Old Jan 31, 2007 | 11:05 PM
lonsal's Avatar
You need to hook up a ground from the relay to the parking brake too, but I'm sure you can figure that out from the wiring diagram in the 1986 Camaro Service Manual.
Lon
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
