1990 Camaro RS anti theft system HELP!
Old Feb 2, 2007 | 10:00 AM
kmk103's Avatar
i have a 1990 camaro rs and the battery drained and now the anti theft is enabled the car cranks but the fuel pump doesnt turn on.can someone help me with this?
Old Feb 2, 2007 | 08:43 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
There is a chip in the key which must match a specific resistance with the antitheft module. If it matches, then the antitheft module supplies ground to the starter enabler relay. If the key doesnt match, then you must wait 3 minutes to try again. Your problem is not vats related. I would start with the fuel pump relay and use the red test circuit on it(jumper to 12v). Listen if it primes.
Old Feb 3, 2007 | 12:57 AM
chevhedz28's Avatar
Car: '89 formula,'88 Iroc
Engine: 350,305
I had this happen to me check the power wires going to the pcm. I had one that was damaged.
Old Feb 3, 2007 | 02:43 AM
MavViper's Avatar
If it was VATS your car wouldn't crank at all. Check the fuel pump relay and also the fuse next to the battery.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
gta90
Sep 15, 2015 04:00 PM
Sanjay
Aug 12, 2015 03:41 PM
