Do I have a bad alternator or What?
Old Feb 4, 2007 | 10:17 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
When I drove my IROC home after buying it a couple weeks ago, I noticed that it took a long time to get the volt meter back up to 12v after taking a few tries to start it in the cold weather with a defunct choke. Also, when I turned the blinkers on, the volt meter flicked in unison with the blinkers. Now I've got a very tame stereo wired up (Head Unit + 2 30W RMS 6.5" speakers) and if I turn the lights on while the head unit is on, the head unit cuts out and won't go back on until I turn off the lights (mind you I was running the engine at about 2k RPM and the battery had just been fully charged with a wall charger when this happened). I can't see any of these problems being caused by wiring... I completely forewent the car's stock wiring when I installed the stereo, so it should be completely seperate from the charging system, it has a hot lead for constant power on to the deck and then another wire with a switch in the middle to simulate the accessory position in the ignition circuit, the ground is good and the stereo wires are all new. I suppose the only other option is that the battery is just getting ready to give up the ghost, but I have left the car alone for about 4 days between times I've worked on it and it seems to hold a charge. That and the battery ran for 3 hours today at 12.0v playing music as I worked on the car before I put it on the charger.
I suppose I should take the alternator in for testing and if it's good I'll try replacing the battery. Any opinions?
Old Feb 4, 2007 | 11:08 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
Transmission: 700R4, lots of Mods
I would get a volt meter and read the battery voltage (motor off), then start the car and read battery voltage, the voltage should be anywhere from 12.5 to 14, espically on a cold start. Alternator's are more efficient when cold. The Voltage should be a bit higher, if your battery was fully charged. If your getting 13-14 volts then I would check out the battery.
Good Luck
Hotrodboba400
Dec 10, 2019 07:07 PM
92firebirdguy
Sep 1, 2016 07:53 AM
sahlomonic
Sep 20, 2015 07:15 PM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
