whis is this part?
Old Feb 9, 2007 | 02:13 PM
1987camarosport's Avatar
Car: Camaro
Engine: worked 350
Transmission: automatic
Axle/Gears: 3:73
whis is this part?
hey i have a black plasic piece infront of me with the numberTRW 14103304 it looks to be some sort of relay or capacator. its in the wiring where the ac used to be its in the loon for the old ac fan motor
can you ID that and no i need it if i do not have ac i unplugged it and ran the hear and had no problem let me know thanks JOe
Old Feb 10, 2007 | 11:22 AM
Vader's Avatar
It is a relay. That P/N relay was used for several purposes, like MAF power, AC clutch, burn-off, and likely other uses. It may not have adequate current capacity for the fan motor, and replacement with a relay rated at 30A is recommended for fan duty. If it happened to be the AC clutch relay, you obviously can do without it if the AC has been removed.
To be certain, verify the wire colors in the harness connected to it. That should help identify the circuit.
Old Feb 10, 2007 | 06:23 PM
Car: Camaro
Engine: worked 350
Axle/Gears: 3:73
it was for the ac i remoed it all and cleaned it up and it works purfect , thanks fo the help
customblackbird
Aug 15, 2021 10:16 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
