91 rpm not working
Old Feb 16, 2007 | 01:46 PM
jaysfs's Avatar
Car: 91 z28, 07 trailblazer ss
Engine: lt1lt4 hot cam,ls2
Transmission: t56
91 rpm not working
I just got a 91 rs and the rpm gauge goes all the way past 7000 rpm and stays there. it sometims goes back to 0 but when i turn the key on and start the it shoots back too 7000 and stays .any ideas?
Old Feb 16, 2007 | 02:26 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Have you checked the white wire off of the coil?
Old Feb 16, 2007 | 03:31 PM
smartman__007's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI (LO3)
Axle/Gears: 3.08
LOL I love doing this. If the wire is good coming from the coil, which I'm 50% sure it is, check out this thread. https://www.thirdgen.org/forums/elec...highlight=Tach read it in it's entirety and that will help you to determine if just some resisitors went to heck in the cluster. Just be careful when removing the cluster. In the bottom right hand corner of the cluster behind the black plastic surrounding the gauges is a type of "Module" that can be slid out to test the leads. IIRC it's pin # 4 and 10 that the resistor goes to heck. Use the thread and it'll explain it wonderfully. For reference mine was off and I replaced mine with a 196K resistor and it seems to work within 100 RPMS.
specialized
Jun 18, 2022 09:26 AM
Reddeath210
Oct 6, 2015 08:20 AM
Irocohio
Aug 12, 2015 08:03 AM
