Turn lights on, fuel pump pulses ?
Old Feb 19, 2007 | 04:24 PM
Twelvz's Avatar
Car: 89IROC
Engine: Forged 355 AFR195
Transmission: 700R4 Vigilante Converter
Axle/Gears: Strange 12 bolt 3.73
Situation:
I just got done putting my 89 IROC back together. Jacobs ignition, clifford alarm, batter relocate are the only electrical mods. I have everything hooked up save the windshield wiper motor and the hood latch sensor for the alarm. I turn the master power on (from remote on/off b/c of the battery relocate) turn off the alarm, turn the key to the one position, fuel pump pulses...here's the thing, if I open the door...fuel pump pulses again, or if I turn on the lights fuel pump pulses again. I beleive I have everything ground and everything seemingly works (radio, all lights etc...). I have no idea whats causing this.
Oh yeah the car won't start either and I have 42psi, and spark.
Anyone know what can cause this fuel pump pulse issue, I assume it's a ground, but I don't know where I went wrong ?
Thanks in advance
Rob
Old Feb 19, 2007 | 09:02 PM
91 355 z28's Avatar
well it sounds like u have some sort of a backfeed going on.. wut lights is it that cause the pump to pulse? interior? dash or dome? and u should double check fuel pressure because as little as 2 psi wrong can cause a no start.. i would try checking things like common grounds.. or common hots.. i know it sounds like hell but go through ur diagram for the alarm again.. especialy if u had to splice into the back of the fuse block.. the fuel pump is getting power from another circuit so try locating its wires in the areas where u had to splice for the alarm.. good luck electricity sucks
92camaroJoe
Jul 29, 2023 07:57 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
