wiring tach
Old Feb 19, 2007 | 07:09 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
wiring tach
how do you wire up a new tach? which wire does it connect to? also how do you disconnect the old tach so it doesn't read anymore?
Old Apr 20, 2007 | 10:28 AM
Re: wiring tach
bumb
Old Apr 20, 2007 | 10:53 AM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Re: wiring tach
Iwired mine to the white tach trigger wire to coil.Do you have the externally mounted coil.Did your tach come with instructions?
eightsixseven
Dec 16, 2024 01:50 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
stalkier
Aug 7, 2015 04:49 AM
