fuel pump fuse melted,slot it goes into.
Old Feb 22, 2007 | 03:19 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
what would make the fuel pump fuse melt instead of blow,and it got so hot it melted the fuse box where it goes in? it must have done this the last time had it fired up,or while it was sitting that was 3 weeks ago.i found the problem while trying to start it yesterday.
Old Feb 23, 2007 | 03:17 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
thats a rare problem, but its not unheard of.
a bad connection on the melted leg of the fuse is what causes it.
you'll need to replace that connector in the fuse box on the melted side.
if the box is damaged too badly to properly hold the replacement connector, you can move that fuse to an unused location. if you don't have a unused spot in the box, you can pull the box down & splice in a replacement fuse holder. its best to solder the wires if possible.
you may want to pull each of your other fuses & check them for corrosion & signs of over heating.
Old Feb 23, 2007 | 03:37 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
thanks i'll check it all out.someone said something about the oil sending unit shorting out that causes it also ,but the previous owner put a after market gauge in it and i can't find the original wire.
Old Feb 23, 2007 | 03:53 PM
DENN_SHAH's Avatar
no problem.
if it was an actual short, the fuse would pop right away.
good luck
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
