Power lock issue
Old Feb 27, 2007 | 03:39 PM
camarorida91's Avatar
Power lock issue
If anyone could help me with this I would be a very happy person. I am installing an alarm and keyless entry system in my 1991 Camaro RS. I have to tie into the power lock control module and I'm unsure of where it is. Can anyone tell me the location of the module. I've been told a few different things. Thanks.
Old Mar 2, 2007 | 11:33 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
LOCK, STOCK AND STOCK CAR
It’s behind the left lower dash area near the door grommet.
Happy Racing !
— If people drove any slower
they’d be going backwards —
Old Mar 7, 2007 | 02:25 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
That's correct, or it could be behind the left kick panel (is on mine).
One thing to watch out for. The door lock relay uses a positive trigger (12V will lock or unlock the car) while many alarms use a negative trigger (they send a grounding signal to lock or unlock the doors). Make sure your alarm puts out the positive trigger for door locks otherwise you'll be seeing blown fuses.
I had to hack into my new alarm and modify it to put out positive trigger signal.
Hope this helps any.
Lou
Old Mar 7, 2007 | 07:39 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
IF you need to reverse polarity as mentioned above, there is an easier way than hacking into anything - simply use a relay. You can have a negative signal complete a circuit that activates the relay and sends a positive signal to your door lock actuator.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
stalkier
Aug 21, 2015 01:54 AM
