ecm questions
Car: 86 Camaro
Engine: 2.8L mpfi V-6
ecm questions
ok well after testing every stinkin wire on my car we finally traced it to the computer being toast. So my question is what computers can i use? i have a 1986 Camaro 2.8 with an automatic tranny. I figured like one out of another camaro of the same year or close would work or maybe even a S10 computer. and another question does anyone have one for sale that would work or could you maybe point in the right direction as to who might have one... I already checked Advanced Auto and Autozone, and neather is looking good... thanks guys
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Re: ecm questions
Hi
You might want to repost this question in the DFI-ECM forum, a little further down the page.
https://www.thirdgen.org/forums/dfi-ecm/
AC Delco does have a remanufactured ECM for you car. Their site is
www.acdelco.com
The AC Delco Part Number is 88999128 for a 1226870 ECM. Note that this ECM was used on a number of Chevy and Pontiac veichels from 1985 - 1989. One thing you can do at the Delco site is generate a cross reference list of all cars that ECM was used on. Seems like there were 42 or so. A good list to have if going to the junk yard
You should also be able to go to your local GM dealer with the ECM number and your VIN to see if they can locate a unit. (Most likley remanufactured)
So I expect you should be able to find one in a junk yard, but the car you take if from should have the same engine, tranny, ac or non ac, etc. so all the inputs and outputs match. I believe that even though the ECM was the same in a number of car the programed memory was different, depending on the engine and options on the car.
Good luck on getting your car running again.
Dave
www.acdelco.com
You should also be able to go to your local GM dealer with the ECM number and your VIN to see if they can locate a unit. (Most likley remanufactured) So I expect you should be able to find one in a junk yard, but the car you take if from should have the same engine, tranny, ac or non ac, etc. so all the inputs and outputs match. I believe that even though the ECM was the same in a number of car the programed memory was different, depending on the engine and options on the car.
Dave
Car: 86 Camaro
Re: ecm questions
thanks for all the information... and sorry i kinda posted in the wrong spot, sorta have a hard time deciding because of the problom but eather way thank you very much.
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: ecm questions
You're memcal (the programming chip) is most likely fine. Just find another 1227730 ecm and swap the chip! if not, I have a 1986 2.8l computer (1227730) for a t-5 transmission that I can sell to you.
Edit-
found this little gem for you
https://www.thirdgen.org/ecminterchange
Edit-
Car: 86 Camaro
Re: ecm questions
wow thank you so much.... and i might jsut take you up on the offer of that computer... cuz the closest junk yard... well lets just say he ain't the nicest guy to deal with.... send me a pm with a price if youd would...
oh and with shipping cost if you could to 17812 in pa... thanks
Last edited by 86camarokid; Mar 21, 2007 at 07:42 PM. Reason: Automerged Doublepost
