tach wiring help
Old Apr 2, 2007 | 06:44 PM
Form88's Avatar
Car: 1988 Firebird Formula
Engine: 305 L03
tach wiring help
I am putting in an autometer tach in my 83 t/a lg4. I found a good ground, have one of the 2 12v wires hooked up. Im almost positive i found the tach wire (i think its white) Now all i need is a 12v dash light source.
Could i get this from my radio wiring? if so...What color would the wire be?
Or i could also tap into the gauge cluster wiring, but i also need to know
what color the dash lighting wire is from that as well.
....or is would there be an un-used slot in the fuse block i could use as a loast resort?
thanks
Jim
Old Apr 2, 2007 | 06:56 PM
j dezzy's Avatar
Car: 87 TA
Re: tach wiring help
You could use your radios power, I've got my CB hooked up to the radios power. a couple other options could be the center console light, the gear selector light, the lighter, the HVAC light. those would be your best bets. The radios ACC wire is yellow and the constant is orange.
Old Apr 2, 2007 | 08:10 PM
Form88's Avatar
Engine: 305 L03
great, thanks alot.
Old Apr 2, 2007 | 08:14 PM
j dezzy's Avatar
Car: 87 TA
eightsixseven
Dec 16, 2024 01:50 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
stalkier
Aug 7, 2015 04:49 AM
