headlight??
Old Apr 3, 2007 | 08:56 PM
firechicken76's Avatar
Car: 88 Trans am GTA
Engine: 2002 Ls1
Transmission: t-56
Axle/Gears: Ford 9" 4.11 gears w/ locker
headlight??
my popup headlight on my right side just started acting up it wont go down, i opened the hood to check it out and the thing that turns when the light goes up and down started working in short spurts, anyone ever heard of this?
Old Apr 9, 2007 | 12:16 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
Transmission: 5 Speed Manual
Axle/Gears: Stock Rear End
Re: headlight??
sounds like a worn gear
Old Apr 9, 2007 | 08:07 PM
Engine: 2002 Ls1
Transmission: t-56
Re: headlight??
seems like its working good now, weird.
Old Apr 9, 2007 | 10:02 PM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
Re: headlight??
If it continues to happen you may have to replace the plastic bushings- do a search- I did both mine for under $10.
Old Apr 10, 2007 | 01:11 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: headlight??
1982-86 is the 3-wire motor. COMPLETELY DIFFERENT than the 1987-92 2-wire motor. I sell kits fo fix both, but for the early Firebird 3-wire motors you'd have to disassemble it to see which gear yours has. Some had striaght-cut gears. My kit won't repair that version. It must have gears that are cut on an angle for my kit.
Lon Salgren
Top-Down Solutions
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
