Atermarket 140MPH Mechanical speedo for 82-85 TA?
Old Apr 25, 2007 | 09:58 PM
wrapper8758's Avatar
Car: 1986 trans am, 1985 TRANS AM WS6
Engine: 305 4bbl,305 TPI
Transmission: 700r4,700R4
Axle/Gears: STOCK POSI DISC
I saw a 140 MPH mechanical speedo for 1982-84 TA for sale on ebay.I have an 85 TA 305 TPI with the 80 MPH mechanical speedo. I e-mailed the company selling it questioning if it works on 1985's also with tpi,without any modifications,and he says it will work AS IS without changing the gear in the Trans that hooks up to the speedo.(no ECM plug and re-wiring from an 86-up donor car needed also I'm assumig then also?)
Is this possible?Has anyone done this without having to upgrade to electronic speedo/donor car ECM plug modification and VSS and gear swap?
It sounds too good to be true....... The seller is axmn46. Anyone ever baught this from them before ?
Old Apr 30, 2007 | 05:29 PM
Re: Atermarket 140MPH Mechanical speedo for 82-85 TA?
http://cgi.ebay.com/ebaymotors/ws/eB...5535953&rd=1,1
Heres the link...
Old May 1, 2007 | 11:54 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Paul, if you are swapping in a mechanical cable driven 140 mph speedo in place of your mechanical cable driven 80 mph speedo, no other mods should be required. Both speedos should be calibrated to read the same mph at any given drive cable rpm. So, if your current speedo is accurate, then the replacement should be accurate as well - it will just have less resolution, as its full scale value is greater than that of the original speedo.
Old May 1, 2007 | 05:34 PM
Thanks Tim,I didnt wanna waste the money if it was useless.I wasnt sure if this was a doable mod .That one sold for 121.50,but im gonna call them to fid out the purchase price.
Does anyone know of another reputable speedo shop to deal with,preferably in NY or northern NJ?
THANKS!
Lbibb
May 5, 2016 12:00 AM
sjorgens
Oct 1, 2015 07:54 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
mfp189
Sep 27, 2015 09:25 AM
