oil presure gauge dont work
Old Apr 27, 2007 | 03:47 PM
craparo's Avatar
need help ! trying to get my oil presure gauge working it has not worked since moter swap 305 fuely to 350 carb its the only gauge that aint workin tryed to hook it up with the old sending unit and still nothing it drives me nuts got 2 aftermarket gauges in the car a tach & oil presure want to get all the factory gauges working ---would the factory tach have to be hooked up for the oil presure gauge to work--- or ????what
Old Apr 28, 2007 | 09:43 PM
djtricia's Avatar
Car: 1986 Z-28
Re: oil presure gauge dont work
Does the gauge needle go to the high end of the gauge when you turn on the ignition? If it does try grounding the wire that is supposed to go to the gauge. It should then read zero pressure. If it does that means the sending unit is bad and you need a new one. Otherwise there is something wrong with the wiring.
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
Reddeath210
Oct 6, 2015 08:20 AM
Navy8125
Aug 21, 2015 09:32 AM
ChevyZ71
Aug 13, 2015 07:30 AM
