Driver's Side Power Window doesn't work?!?
Old May 19, 2007 | 09:24 AM
Red_Bully's Avatar
hey i'm not a big car expert and was wondering if someone could tell me why my power window on the drivers side doesn't work at all! (i know this might be the cause of several things but please guide me so that i know where to start looking) I'm thinking maybe the motor. If thats the problem then where is the motor for the power window located and wat would be the part # i would need to replace it? thx
Old May 19, 2007 | 09:50 AM
Epsilon2k's Avatar
Car: 1992 RS
Transmission: Stock Auto.
Axle/Gears: Stock
Re: Driver's Side Power Window doesn't work?!?
The motor is in the door and it's really not fun to change. I took a meter to the switch to check for power then when I pulled the door panel I checked at the motor for power. Just to make sure I wasn't shorting in between. Ground and drilled some rivets, got the old one out, tried lining everything up, swore, swore some more, figured out why I was swearing and riveted the new one back in with a really crappy rivet gun. Not fun at all. It looks simple but it fought every step of the way. I bought a window motor from ebay so I figure i'll have to do it again someday.
Old May 19, 2007 | 01:11 PM
klez's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L Ported SLP Runners and Intake
Transmission: 700r4 w/ shift kit
mine work but are just slow, the drivers side is decent but the passenger side i dont know about, i always hesitate to put it down cause i dont know if its gonna want to come back up, but it always has
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
