Lights wont pop up
Old May 28, 2007 | 10:47 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
Lights wont pop up
I have a problem. I was replacing my timing chain + gears, and went to turn on my headlights, and the lights turn on, but the lights dont pop up (They worked before). The motors aren't even getting power (or so it sounds). The only thing I unplugged was the AC Compressor, so is there any plugs that are near by that are for the light motors? Where is the ground for the motor? Any ideas?
Old May 28, 2007 | 11:13 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
Re: Lights wont pop up
The motors ground on the radiator support on each side of the radiator. It sounds like the module on the firewall isn't getting power.
Old May 29, 2007 | 06:50 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
any idea where this module is? I gave a general look around and didnt see anything unplugged. I did have to jack up the motor to replace the pan, so its very possible its unplugged, cut wire, or damaged. thanks
Just went out and tryed it, and they went up the first time, and every time after that they didn't. So my guess is that something is damaged.
Old May 29, 2007 | 07:16 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
The module is on the firewall to the right of the wiper motor and above the brake booster.
RazorN8
Jan 7, 2022 11:44 AM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
Jae992
Aug 27, 2015 09:07 AM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
Omega
Aug 10, 2015 12:46 PM
