Steel Braided Sleeving as Heat Protection?
Old May 30, 2007 | 02:09 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
I have some of that steel braided sleeving you put around your hoses to make them appear like real bradied hoses which I defenitly won't use.
Would this be good to put over wiring for heat protection? I'm talking mainly about my starter wiring that is dangerously close to my headers.
Old May 30, 2007 | 10:32 AM
79frankenstein's Avatar
Car: 86 z28
Engine: 350 sbc
Transmission: TH350
Re: Steel Braided Sleeving as Heat Protection?
I wouldnt use it because steel is a great conductor not resistor, so it would take the heat in and just melt the wires probably.
Old May 30, 2007 | 11:15 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
I was definitely thinking that but its got to be better than plastic wire loom...or should I use both?
Old May 30, 2007 | 11:35 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you want to protect your wires from heat, try some insulating tape or header wrap or something similar.
Old May 30, 2007 | 11:46 AM
Car: 86 z28
Engine: 350 sbc
Transmission: TH350
im shure if you go to summitracing.com you would be able to find some form of wire wrap or cover, i know that they carry alot of different types of spark wire sleeves and such
im sure if you go to summitracing.com you would be able to find some form of wire wrap or cover, i know that they carry alot of different types of spark wire sleeves and such
Last edited by 79frankenstein; May 30, 2007 at 11:47 AM. Reason: Automerged Doublepost
Old May 30, 2007 | 10:12 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Well I have some sleeving I bought from McMaster Carr (that site is the sheeeeet BTW...one of my favorites to browse around) thats designed for extremely high heat and I ended up using that since its also what I have my starter cable wrapped with.
I just wanted to see if this would be a decent idea, I want to use up this braided sleeivng I have. I guess I'll stick with this as a wire loom substitute to protect against wires rubbing on other things.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
