Clear Connector by ECM???
Old Jun 1, 2007 | 02:34 PM
cabech984's Avatar
Car: 1990 Firebird
Engine: 6.0L LQ4
Transmission: 4L60E 4000 Stall
Axle/Gears: 3.23 G80 (01 TA)
Alright, I am currently doing a 3.8L swap to my 3.1L Firebird. I am trying to figure out which connector this is. I dont have a picture, but it is part of the Engine Harness by the ECM Connectors. It is a clear connector w/ seven slots in it. It connects to some dash wiring(I believe). I need to know what it is and if anybody can post a diagram of it, that would be great too. Thanks in advance!!
Chris
Old Jun 3, 2007 | 10:17 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Clear Connector by ECM???
You might be referring to connector C207 but I'm not sure. Do a search here with "C207" and see from the pictures if that's what you are looking at.
If you need the pinouts, we have them on the TechDB page here: http://www.austinthirdgen.org/module...howpage&pid=22 (scroll down to the connector pinouts)
Hope this helps.
Lou
Old Jun 13, 2007 | 07:47 PM
cabech984's Avatar
Car: 1990 Firebird
Engine: 6.0L LQ4
Ive read that it is C208 or C207. It is black/white. I need a diagram for a 1990, cant seem to find one anywhere I need the connector end view for it!!
Old Jun 13, 2007 | 10:18 PM
BigBadLou's Avatar
Engine: TPI
The C208 would be on the driver side. If you're looking at a connector by the ECM on the pass side, it's most likely the C207. Check the wire colors, that should be a dead giveaway.
Hope this helps.
Lou
Old Jun 13, 2007 | 10:37 PM
cabech984's Avatar
Car: 1990 Firebird
Engine: 6.0L LQ4
Definatly the C207 it's black/white connectors. Idk where I got clear from
I think I found what I need actually skimming through the search for about an hour. Ive had the connector end view for the Grand National Harness and have been searching for this one.
Nick McCardle
Sep 10, 2015 08:36 PM
Ironhead38
Sep 7, 2015 02:26 PM
Chevy86 IROC-Z
Sep 7, 2015 01:13 AM
middian
Sep 5, 2015 01:42 AM
