Please Help. Tach question
Old Jul 21, 2007 | 10:17 AM
Tbuck2007's Avatar
Car: 1989 Pontiac Trans Am
Engine: Small Block 400
Axle/Gears: 2.73 Limited Slip
Hey guys.
I'm trying to hook up my stock tach in my 89 trans am..but I have no idea where to look. I know its probably a plug if I'm not mistaken, and plugs into the distributor, but I dont know where. I see two plugs on the right side of the distributor, but stuff is already plugged into them. What wire am I looking for..any help? any diagrams? thanks.
Old Jul 21, 2007 | 11:00 AM
89N10GTA's Avatar
Car: 1989 GTA
Engine: 355 with Super Ram
Axle/Gears: 3.73 10 bolt with a True-trac
Re: Please Help. Tach question
that car should be pre wired for the tach. so i guess i don't really know what you would have to hook up. but after market tach come off the coil not the distributor. if i'm not mistaken so does the stock tach.
Old Jul 21, 2007 | 11:36 AM
Tbuck2007's Avatar
Well we did an engine swap, it had a 305 F.I motor, we put a small block carbed 400 in it..I just dont know what to look for plug wise.
Old Jul 21, 2007 | 11:44 AM
89N10GTA's Avatar
Car: 1989 GTA
oh ok
it should be the white wire coming off the coil
i just looked it up for you. tap into that wire and you should be good.
Old Jul 21, 2007 | 12:12 PM
Tbuck2007's Avatar
Kinda a noob..the coil? The distribuator? The wire that plugs into the tach spot on the distribuator is brown..spliced into a red wire.
Armored91Camaro
Aug 25, 2015 12:01 PM
redmaroz
Aug 16, 2015 11:40 PM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
