?gauges and sensors
Old Aug 13, 2007 | 05:02 PM
C.M.Jones's Avatar
Car: 84 Camaro, 90Firebird, 87Transmaro
Engine: custom 5.7, 5.0 , 6.5 Turbo diesel
Transmission: 4spd, auto, auto
Axle/Gears: 2.77 posi
?gauges and sensors
i have an 84 camaro with an older engine (70s) and no computer
I want to hook up the Oil presure and Tempature unit to my stock gauges how can this be done, all the other gauges work fine
Old Aug 13, 2007 | 05:07 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: ?gauges and sensors
Put your stock senders on your new engine.
Old Aug 13, 2007 | 05:18 PM
C.M.Jones's Avatar
stock sensors are LONG gone and I don't know what wire is supose to go from the unit to the gauges
I can see buying a temperature unit but what about the oil pressure one? is there somewhere that can tell me all the places on a sbc I can put sending units?
Old Aug 13, 2007 | 05:57 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Go down to the parts store and get some new ones then.
A coolant temperature sender can go in any port that has coolant behind it (usually the ports int he head), an oil pressure sender can go in any port that has pressurized oil behind it (on the top of the block beside the distributor, or above the oil filter).
Old Aug 13, 2007 | 06:14 PM
C.M.Jones's Avatar
is there a way to find the gauge wires under the hood WITHoUT puling apart the dash??
Old Aug 13, 2007 | 06:18 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Check the wiring diagram for the car and find the wires with the colors listed. They're both single wire connectors.
Old Aug 13, 2007 | 06:20 PM
C.M.Jones's Avatar
im looking at that now but im sure theres more than one dark green wire under there
Bubbajones_ya
Jul 6, 2024 08:32 PM
TrevinE
Sep 14, 2015 03:20 PM
86IROC112
Sep 11, 2015 04:04 PM
FormulasOnly
Sep 10, 2015 09:07 PM
