PRO COMP PRODUCTS WARNING!!!!
Car: 1989 IROC Camaro
Engine: Stealth Ram 355
Transmission: WC T-5
Axle/Gears: Torsion 3.42 Posi
Something happened with my connection last time, so here is the shortened version.. This is a new out of the box distributor!! It was used to start my 305 TPI Camaro at my dad's garage, pulled the car on to a rollback, then backed it off the rollback at my new house. When I took the motor out the plug wires pulled the terminals out. If you look at the picture you may see the crack between the lines. Imagine if this would let go about 6000 RPM or so...... BUY MSD,GM,ACCEL.... Last edited by Iroczracer; Sep 6, 2007 at 11:37 PM.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: PRO COMP PRODUCTS WARNING!!!!
yea, you pretty much need to steer clear of anything made by pro-comp
no green
Jan 9, 2016 09:22 PM
