passenger side door lock actuator probs
Old Sep 10, 2007 | 09:33 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
My passenger power door actuator doesnt work. Im not sure if its the actuator itself or the relay that supplies power. Is there an easy way to find out for sure? Where is the relay located as well?
Old Sep 10, 2007 | 11:16 PM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Re: passenger side door lock actuator probs
If you search, you will find some recent discussions on items that may be causing problems with the power door locks.
If you look at message #6 in this link, the first attachment will show you where the relay is. You will have to remove the driver's side kick panel to access it. You can also find a link in message #2 for wiring diagrams....
https://www.thirdgen.org/forums/elec...rritation.html
Dave
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
g.l.mos
Aug 22, 2015 12:02 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
