TPS trouble...
Old Sep 22, 2007 | 12:33 AM
streetlthl's Avatar
TPS trouble...
Ok Ive read all the threads on setting the tps voltage, adn I have a new problem not yet found in previous threads. You set tps voltage at .54 +/- .075 volts right? OK I only have .508 volts coming out of the wiring... and im getting a code 22 tps low voltage... I replaced the tps, but I cannot turn the sensor far enough forward to make any difference because i dont have .54 volts coming out to start with.... is this normal????
92camaro350cci
Oct 14, 2015 09:29 AM
Fred SS
Oct 12, 2015 11:27 AM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
