Connectors near ECM Unplugged, VSS, Speedo
Old Sep 30, 2007 | 12:29 PM
PV9685's Avatar
Car: 89 Firebird Formula
Engine: 305 Vortec, Single-plane, 4 barrel
Transmission: T5, soon 700R4
Axle/Gears: 88 10 Bolt, Disc, Auburn, 3.23
89 Formula 305 TPI
I have been troubleshooting my speedo/VSS, neither has power.
Near the ECM, from the wiring harness there is a two pin connector for the VSS and a multipin connector which has the speedo wire in it.
Both are unplugged and I do not see a way to plug them into the ECM/ ECM harness, is there a module/connector I am missing??
Two connectors at top of image.
-Dave
Old Sep 30, 2007 | 01:50 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Connectors near ECM Unplugged, VSS, Speedo
Looks like you're missing a DRAC module. This converts the 4x signal from the magnetic VSS to a 2x signal that the ECM can use.
Old Sep 30, 2007 | 06:02 PM
PV9685's Avatar
Thank You SOOOO Much!!!
You're the man!
-Dave
Old Sep 30, 2007 | 09:52 PM
PV9685's Avatar
Actually, does anyone know if these modules differed between transmissions/engines/gear ratios etc?
Because it looks like I'll be hunting in the junkyard.
Thanks,
Dave
Old Oct 1, 2007 | 07:40 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
P/M Sent !
GTAman
Jul 3, 2024 07:29 PM
db057
Apr 28, 2019 07:45 AM
TrevinE
Sep 14, 2015 03:20 PM
Chevy86 IROC-Z
Sep 7, 2015 01:13 AM
middian
Sep 5, 2015 01:42 AM
