no gauges after swap
Old Oct 5, 2007 | 04:50 PM
88z28350's Avatar
i've had the car for a week now its an 88 camaro and bought it with the gauges not working. They put a carb. 350 and removed the computer. When im cranking it the gauges will move but once started they wont work. the fuel goes all the way up the rpms go up the speed stays down nothing moves. The volt meter works tho. What could be wrong? How do i take off the cluster? i removed the outer plastic piece but didnt have time to figure the rest. i tried to trace the wires under the hood but its such a mess i dont know where anything is since there is no computer
Old Oct 6, 2007 | 02:36 PM
88z28350's Avatar
Re: no gauges after swap
no one has any ideas? i need help! oh well ill just give it to a mechanic
Old Oct 8, 2007 | 09:54 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
When they put the new engine in, they might not have hooked up any sensors. You'd need to look for sensors on the engine (coolant temp, oil pressure) and check the wires.
The fuel gauge won't be affected by an engine swap. Any chance the gas tank is just full?
If the tach shoots up and stays there, you got a bad tachometer gauge.
And the speedometer is operated by a cable from the transmission tailhousing. You'd need to find it on the tailhousing and make sure that it's connected.
Hope this helps.
Lou
Old Oct 9, 2007 | 03:18 PM
88z28350's Avatar
Yeah i guess things are just not connected because there is unplugged wires everywhere in the engine bay. But the fuel isnt full, the gauge just doesnt move. it has aftermarket gauges , like the tach, oil, and water temp and they work. so im really only concerned about the fuel. I know im wasting way to much money on gas because i keep filling up everyday so i dont run out lol
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
355sbcTPI
Aug 19, 2015 04:38 PM
ChevyZ71
Aug 13, 2015 07:30 AM
