How do i hook up the Heat?
Old Oct 18, 2007 | 02:49 AM
tigercyberslash's Avatar
Car: 1984 Camaro Z28
Engine: V8 350 ci
Axle/Gears: Posi, Disk brakes all the way aroun
Hello, Just wanted to know what all parts consist of for the heating system, I'm not sure what's there or whats missing if anything, I know that the last owner put a 350 engine in and took out the ac cylinder but the rest a/c seems to be there?? , The heat buttons and stuff are all there just nothing happens when u turn it on.
So what should I look for for making the heat work, I don't really need the a/c working just heat for winter.
Just replaced my rubber seals around the side mirrors, due to wind blowing through them when you had the window all the way up while driving, The olds ones were really bad, better check yours soon
Old Oct 19, 2007 | 12:32 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Re: How do i hook up the Heat?
Take a look at this thread in the Cooling board for an electrical wiring diagram. You can also search that board for the vacuum diagrams for controlling the air flow.
https://www.thirdgen.org/forums/cool...t=#post3331316
This isn't the best scan, but it will give you an idea of what's involved electrically.
Dave
Old Oct 20, 2007 | 01:19 AM
Engine: V8 350 ci
hahaha I tried turning on the heat today on my camaro and it works!! lol but hey it blows strong threw the vent thats up by the front windshield but not out the vents even when i tried turning it on that setting, what can cause this problem?
Old Oct 20, 2007 | 03:20 AM
ZimGTA's Avatar
Car: 88 GTA
Engine: 383
Transmission: 700 r
There is no vacuum to the heater controls. Defrost is the default setting. There should be a small hard line that goes through the firewall behind the pass. side head.
Old Oct 20, 2007 | 01:12 PM
Engine: V8 350 ci
a small hard line? what does it lead? what should i do with it? is that the vacuum.?
Old Oct 21, 2007 | 12:12 AM
ZimGTA's Avatar
Car: 88 GTA
Engine: 383
Transmission: 700 r
It is tubing, a small vacuum line. It should come from the intake, mine splits and goes to the cruise control also.
Old Oct 21, 2007 | 12:46 AM
Yes, it is a vaccum line that starts at the vaccum tank, located just to the left of the brake booster. The line runs along the firewall behind the dist and then combines with an wire harness that goes throung the firewall behind the pass. side head. Take a look at thses diagrams and as I suggested before visit the COOLING board and SEARCH for "vacuum schematics" for some better diagrams of how the vacuum is connected to the heat and A/C air flow diagrams.
Dave
Attached Thumbnails How do i hook up the Heat?-82_vac_heat_1.jpg   How do i hook up the Heat?-82_vac_heat_2-.jpg
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
Gordonr1973
Sep 29, 2015 11:59 AM
