Fog lights
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
Fog lights
I push the buttons to turn on my fog lights and they didn't work
What should I do?
What should I do?
Car: 1997 Grand Prix GTP (for now)
Engine: 3.8 sc
Re: Fog lights
check if you have power to the switch (start by checking fuse)if so then see if it goes to the lights, if so then you have a bad ground, if not you have a bad wire somewhere (or bad switch)
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Fog lights
What should I do?
What should I do?
Engine: 350/350/LS1
Re: Fog lights
Ok so I replaced the bulbs and pushed the button and they didn't go on niether did the orange light next to the switch
Car: 1991 Trans Am GTA
Engine: 502 Ram Jet
Transmission: TKO600-racing gears
Axle/Gears: 12 Bolt Moser-33"axles-3.91 ratio
Re: Fog lights
Maybe you should unmount the part that has three buttons on it which are fog, resitances and if you have hatch button... After unmounting you should check for if the electric is dead or alive at the cables that comes to switches...
Re: Fog lights
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
