fuel tank ground???
Old Dec 11, 2007 | 03:13 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
fuel tank ground???
i have this aftermarket digital dash for my 1986 trans am
where can i find a fuel tank ground for the fuel gauge?
i understand its different from a chassis or engine ground
where can i find a connection to it besides lifting up my carpet?
Old Dec 14, 2007 | 05:50 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Re: fuel tank ground???
Here are the gauges diagrams for an 84 T/A.
I can't see why you couldn't use any chassis ground, as long as it's not flowing a high current. Hooking up to window elevator, door lock,/ or fan grounds might make the gauge jump a little when using these accessories, esp. with the tank near empty.
The sender is usually grounded back there, and the gauges are just grounded to a low-current ground point somewhere in the dash.
Sorry I didn't notice your other post about the same thing.
Attached Thumbnails fuel tank ground???-gauges-1.jpg   fuel tank ground???-gauges-2.jpg
Old Dec 14, 2007 | 10:12 AM
Bobby_80s's Avatar
Axle/Gears: no idea
not a problem thanks for the tips. i didnt know there was a high and low current ground. i'll see if i can hard wire the ground through the dash. i just dont like the gauges being connected by prongs to flat copper terminals. just doesnt seem a good enough connection to me and i want my gauges very reliable.
thanks for the tips
Old Dec 14, 2007 | 03:27 PM
I haven't actually been inside a T/A dash so I'm just assuming the logic of the factory here. To be certain you can find a separate place for a screw and a ring terminal, but I wouldn't worry about a flat terminal being unreliable under those conditions, just avoid any ground points that obviously carries heavy currents.
Old Dec 14, 2007 | 04:36 PM
Bobby_80s's Avatar
Axle/Gears: no idea
i took care of everything,
i hard wired some wires including the 12v and grounds and temp/fuel/oil gauge sender wires while kept using the flat terminals for engine light etc...
works just fine but i need to replace my oil sender since its reading 30psi with just ignition on. i already checked the gauge itself. its gotta be the 20yr old oil sender.
thanks guys
mustangman65_79
Apr 14, 2017 05:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
AkDrifted
Aug 17, 2015 07:45 PM
