Hi i have a 89 camaro and I just got an alarm installed and the people who installed the alarm told me that the wiring for my door sensors were not there. So in other words my alarm does not work for my doors. They told me that I have to fix the wiring and I can bring it back and they will fix the alarm, but I was wondering how do I fix the the wiring for the sensors? thanx for any help in advance
Al Hasse
close
I didn't think there were door sensors on most alarms. The door open trigger is wired to the dome light circuit so that when the light comes on, the alarm goes off.
John in RI
close
- Join DateAug 1999
- LocationRI
- iTrader Positive Feedback100
- iTrader Feedback Score(170)
- Car1984 Camaro Berlinetta
- EngineLT1
- TransmissionT56 6-speed
- Axle/Gears4.11 LS1 Rear End
- Liked:473 Times in 366 Posts
To my knowledge the only camaro to ever get "door ajar" indicators was the Digital Berlinetta from 84-86. In the 84 berlinetta used additional door 'pins' ( similar to the door pins for the interior lighting ) that were installed near the door striker..... in the 85-86 that was ditched for a door sensor mounted directly to the door latch mechanism. There was also an additional sensor placed at the rear hatch during these years.
It's possible that the Digital Dash GTA's also had this feature.
Whoever installed your alarm should have known this !!!! The door open trigger is wired to the dome light circuit so that when the light comes on, the alarm goes off.
Quote:
I think this is what the guy was talking about. So the wiring from those pins are wired straight to the dome light?Originally Posted by Al Hasse
I didn't think there were door sensors on most alarms. The door open trigger is wired to the dome light circuit so that when the light comes on, the alarm goes off. Supreme Member
Al Hasse
close
The door pins supply the ground for the dome light, 12V on the other side of the light comes from the fuse block (20A CTSY)
http://www.autozone.com/images/cds/g...3d80163fe1.gif
