1992 Trans Am turnsignal questions
Old Jan 7, 2008 | 12:28 PM
Tampa Hurricane's Avatar
I have a 1992 Trans Am that I want to modify the rear turn signals. I purchased a set of tail lights from a 1989 Trans Am that I have installed. My turn signal in the rear only has the first bulb flash while it is on, and I have heard that there is a modification that can be done to get all three on one side to flash. What needs to be changed to make it so that all three bulbs flash while the turn signal is turned on? I detailed explanation would be greatly appreciated.
Thank you
Old Jan 7, 2008 | 05:49 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: 1992 Trans Am turnsignal questions
You will need to do one of 2 things.
1.get a harness from an 85-90 t/a or gta and cut the harn. conn. on both the int. harness and the taillight harness and wire them together.
2.get 4 bulb sockets from any third gen bird and wire them into your 92 taillight harn.
I chose option 1
not hard to do when you know what and where to do modifications.
Let me know if you need more info on what method you decide to go with.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
1992 Trans Am
Aug 9, 2015 04:32 PM
