help with my 89 iroc
Old Jan 10, 2008 | 04:52 PM
proxrman's Avatar
Car: 89 camaro
Engine: 472 BBC
Transmission: TH400
Axle/Gears: Dana 60 with 4.10s detroit locker
Hey i was wounding if anyone knows what the relay is behind the drivers side kick panel? there is a plug in that comes out from the harness that runs under the carpet on the drivers side floor and right behind the kick panel there is a relay of some sort that is melted and i dont know what it is for and im just seeing if any one knows what it is
Old Jan 10, 2008 | 04:53 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: help with my 89 iroc
do you have and do they work...power locks??? picture would help for sure and would save a lot of time of diagnosis and speculation if you can.
Old Jan 10, 2008 | 05:00 PM
proxrman's Avatar
Car: 89 camaro
Engine: 472 BBC
Transmission: TH400
ya it has power locks and the do work. the connector has 4 or 5 prongs and it is only 4 or 5 inches off the harness that runs along the floor
Old Jan 10, 2008 | 05:04 PM
84redta's Avatar
can you describe the connector shape wise??? Or take 5 minutes in microsoft paint to duplicate it?
better yet...is there anything in the car that isn't working as it should...inside the car, outside, engine running weird. Anything you can think of may help. Check stupid little things like windshield wiper operation and horn, things like that may help lead us to an outcome.
Old Jan 10, 2008 | 05:14 PM
proxrman's Avatar
Car: 89 camaro
Engine: 472 BBC
Transmission: TH400
I dont know if this will help but the connector is a farley good size one it is roughley 4 to 5 inch long and 1inch wide
did the pic post
Old Jan 10, 2008 | 06:01 PM
84redta's Avatar
i don't see any pics there. 4-5" X 1"...damn...and you said it's underneath the driver side kick panel? I don't know of any other relays that are that big inside there other than the power locks, and all the power lock relay's i've seen are metal casing...idk, i'll wait to see the pic if you can get one up.
BAMiller
Sep 14, 2015 06:38 PM
angel2794
Sep 8, 2015 06:22 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 11, 2015 03:17 PM
