non stoping wipers and vacume thingy
Old Jan 22, 2008 | 12:27 AM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
well i yanked the motor outa my 86 t/a and droped it in my 82. i started wireing everything up and go in to see if all the lights and other electronics worked since the car had sat since 02 well to my surprise everything works even the headlight motors one is a lil slugish though but anyway i fliped the wipers on and they woulnt cut off they will just stay on the slowest setting and i dont know whatbwould cause this of how to fix it. another thing not so much electrical related i guess but next to the wiper motor is a cylinder looking object with vacume hoses coming out of it i have no idea what it is or what it was connected to when i pulled the other motor outa it. my 86 doesnt have this and i dont remeber seeing it on any of the other 3rdgens ive worked on if anyone has and idea what it is let me know please thanks
Old Jan 22, 2008 | 08:14 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
Re: non stoping wipers and vacume thingy
next to your wiper motor would be the vacuum reservoir for the vent/door control in the hvac system. not sure about the wiper motor unless maybe there is a bad or missing ground.
Old Jan 22, 2008 | 11:35 PM
Screamin86's Avatar
sorry for my ignorance but im still not sure what the canister is for or how i need to hook it up or if i even need it at all? thanks for all the help though
Old Jan 23, 2008 | 08:36 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
no problem, basically if you intend to keep the heater and ac system, you will need to have the vacuum res hooked up or only the defroster vents will operate. on the res should be 2 ports, one will connect to the carb on manifold vac. the other line will go into the ac harness going through the firewall. there will also be a one way valve on this line either in the engine bay, or under the dash(don't remember) hope this helps
Hal87
Exterior Parts Wanted
Nov 8, 2015 03:40 PM
Hal87
Sep 26, 2015 09:26 PM
adelane
Sep 9, 2015 08:51 PM
