HELP!!!! My hatch will not latch!
Old Feb 17, 2008 | 07:29 PM
t/agta's Avatar
Car: 87' Trans Am GTA, 88' Trans Am GTA
I was fixing the cargo area light, and after i got it in i put the panels back on and all sudden my wont close. I tried moving around the latch/motor assembly, but i cant get it to close. Can someone please help me?
Old Feb 17, 2008 | 09:50 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Re: HELP!!!! My hatch will not latch!
was a wire unplugged ?
Old Feb 21, 2008 | 10:11 PM
1991ON20's's Avatar
Car: 91 RS, t-topped, man trans.
Engine: 350cid 350Hp crate motor
Transmission: t5 with new stock clutch and parts
Axle/Gears: 3.08 stock -RS
ok i just fixed my trunk latch assembly (pull down). I HAD THE SAME SENARIO AS YOU.
ok GET a volt meter. find all your power sources.... The motor is a Blue wire and also the reverse cycle (or down motion the power is wire is brown)
at the very top of the latch (actual locking mechanism) there should be a lever to turn the interior lights on and off. That also Activates the motor.
Your relay box (little black box to the left of the entire assembly) SHOULD NOT be making a heavy clicking noise every time you press the light switch/motor switch.
ok now after all of the troubleshooting...if it doesnt work then take your motor completely off of the assembly.
get ahold of some wire that you can hook a positive and a neg to your car battery.
take the opposite ends with your hands and put then on the contacts of the motor.
the motor should elevate to the "open" position.
once in the open position replace motor on to assembly.
and your done.
sorry for grammatical or spelling errors.... going on a beer run now
Old Feb 26, 2008 | 08:48 PM
Roadkid91's Avatar
Car: 1987 Trans Am
Engine: LB9
Ok you can move your unit up. Take a 1/2" socket and loosen the 2 big bolts, 1 on each side of the hatch motor assembly. then slide the whole assembly up and tighten the bolts. shut you hatch and it should catch manually and you can unlock it with a key.
Old Feb 29, 2008 | 11:23 AM
Dima's Avatar
Car: 2002 Pontiac Firebird (R.I.P 1992)
Engine: 3.8L Ram Air V6 3800 Series
Transmission: 5spd
Axle/Gears: Unsure
I had the same problem, was always in the down position.
Took out the fuses and it reset it *shrug* if it dont work try it haha
forget what one controls the latch though...
jrdturbo
Mar 31, 2016 02:58 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
formula00ra
Sep 28, 2015 11:50 AM
