Fuel pump relay bypass
Old Feb 26, 2008 | 01:25 AM
f_body_4_life's Avatar
Car: 1988 formula
Engine: 93' LT1 Swap in progress..
I need some info in how to wire up a fuel pump directly to 12v source, What I need to do is get the fuel pump power, I plan on doing this with a on off switch and the 12v power coming from the fuse panel, But I need to know how to access the power wire coming from the fuel pump.
Old Feb 26, 2008 | 07:41 AM
lukn4trbl's Avatar
Car: 2000 SS, M6
Engine: Modified LS1
Re: Fuel pump relay bypass
I don't have the wiring code for your year of car, but if someone can
provide that info, I can draw up a diagram for you.
The bypass is actually quite simple. Once you located the relay,
just disconnect the harness from the fuel pump side.
You will then mate the 12 volt wire to your fused panel switch. Also
ground the circuit as it is isolated.
Do you still plan to use the fuel gauge on the dash?
Old Feb 27, 2008 | 12:47 AM
Car: 1988 formula
The Fuel Gauge works, so your saying if I can get you wiring diagrams for an 88 you can make me a diagram? that would be great. I just need to find the Fuel pump power wire then all hopefully in business the rest should be easy.
Well see if anything on here helps http://www.austinthirdgen.org/index.php?pid=19
Old Feb 27, 2008 | 08:04 AM
lukn4trbl's Avatar
Car: 2000 SS, M6
Try this setup. From the diagram, it seems like it will work fine. The fuel
sender doesn't appear to be linked into this bundle of wires.
Cut the Tan/White wire after the common tie point so that you are only
controlling the fuel pump with your switch. Leave enough length on the
cut side in case you ever want to mate the wires back to stock.
If the 3rd gen is the same as the 4th gen, the relay is located behind the
driver's side kick panel (near the hood release lever).
I would suggest connecting the switch to a source which is dead when
you remove the key (switched power) in case you forget to flip the power.
Old Feb 28, 2008 | 01:11 AM
Car: 1988 formula
Big Thanks now my LT1 runs!!!
Old Feb 28, 2008 | 02:47 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Just out of curiosity, can the stock FP relay not be made to work with the LT1? I wouldn't think anything would be different, except maybe the oil pressure cutoff switch.
Old Feb 28, 2008 | 09:10 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
I was wondering the same thing. You didn't say why you wanted to bypass the FP relay so I didn't question your intent. But I rewired one 3rdgen for an LS1 engine and we got the FP relay hooked up to the new computer no problem. Or did you just want full control over the FP circuit?
Lou
Old Feb 28, 2008 | 12:38 PM
Car: 1988 formula
no my Fp relay wiring was all screwed up Im just doing the switch just to get the car started all go back and wire up a relay in the spring before im driving it all the time
Old Feb 29, 2008 | 12:51 PM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
Axle/Gears: 9 bolt 3.91
You should also put in a fuel pressure cutoff switch incase of a crash. Holley makes one that cuts off the fuel when oil pressure drops below a certain point. I know you will have a switch, but what if you're unconcious.
Old Mar 1, 2008 | 11:29 PM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
the red wire to the "fuel pump prime". where does that go? the previous owner of my car put speaker wire from the red wire on the relay to wherever the destination goes, and that came off, and now the car doesn't start. so where does that go?
Old Mar 3, 2008 | 12:11 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
On a Vette anyway ,that is just to a connector that lets you run 12V direct to the pump bypassing the relay for prime or test purposes
Old Mar 5, 2008 | 01:32 PM
matthufham's Avatar
Car: 90 z28
Transmission: t56
alright just to confirm this, it connects to ground normally
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
