Have V6 in V8 car, tach reads to fast what is the fix.
Old Mar 8, 2008 | 04:30 AM
88ZNX's Avatar
Car: 1988 Camaro IROC Z
Engine: Buick 3.8 V6 turbo
Transmission: th400 with TB
Axle/Gears: Mosser 9" 3.50 9.44@146.7
Hi guys new to this site. I have a GN V6 in the car know and the factory tach reads about 700rpm to fast. Have crane Hi 6 box and sending a 6cyl, signal to the tach wire but it dosent jive with the FAST FXI reading at idel the laptop shows 900rpm the tach is 1500 problem remans consant though entire rpm rang at 6000 on tach FAST records 5200. Im using an adjusable shift light to controll shifts, but would like the tach to be correct also. Any help
Old Mar 11, 2008 | 12:04 AM
jaron's Avatar
Car: 1982 Pontiac Trans Am
Engine: 305 V8
Transmission: TH200
Re: Have V6 in V8 car, tach reads to fast what is the fix.
it sounds like a problem with the tach, from what ive read and know the tachs on these cars are notorious for "lying" so best option if to find a car with a proper working tach and replace it...that would and should be ur best bet, also try and find a new tach from a V6 car, just to be on the safe side
Old Mar 14, 2008 | 12:58 AM
ej1_sleeper's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: stock non-posi
the v8 tachs and v6 tachs read differently. since you have the original v8 tach in with the v6 motor your going to have to find a v6 tach and swap it in, and youll be set from there.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
midge54
Dec 27, 2019 04:14 PM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
