What color are my fan wires???
Old Mar 11, 2008 | 05:43 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Im trying to fix my fan because it woirk when the AC is on but does not take over in higher temps like it should, just replaced the connector, and the sensor itself, looking for opens or shorts in the wiring, so i far i can see that it goes from the connector, up by my AC compressor, along my tbi, then i lose it. The new connector i got from nappa the wire is white but theold one is black, is that correct? Ive heard its green, black bark blue etc and im so confused, i need this fixed, AZ is heating up quick and im screwed without my fan
Im stabbing myself with a needle trying to do this continuity test anyone wanna gimmie some hints before my fingers start looking like i have diabetes??
Old Mar 11, 2008 | 06:41 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: What color are my fan wires???
ok well i just needled through the gren/white at the relay and the black one down on the switch, and there are no breaks there, the clip to the fan is good, my relay is good, is it possible i got a bad sensor??????
Old Mar 12, 2008 | 11:13 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
What temperature do you let the engine reach before shutting it off? The fan kicks in at pretty high temps, like 230 or so (our cars normally run up to 220). If you shut it off too early, the fan is not gonna kick in.
Another local member here had the same issue. But he actually didn't. He was just afraid to let it get a little hotter. Once we did, his fan kicked in and cooled it back down to 220.
Lou
Old Mar 12, 2008 | 10:24 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
well i may have done the same thing, im not sure but i didnt want it to get too hot, im already half way through a new sensor install so im just gonna go through with it, except this time im gonna use some permatex thread sealant for peace of mind
eightsixseven
Dec 16, 2024 01:50 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
LT1Formula
Aug 20, 2015 09:36 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
