Digital Dash TACH not working
Old Mar 17, 2008 | 03:01 PM
SDalt404's Avatar
Car: 1988 GTA
Transmission: 5 Speed
I just got a GTA and the rpm gauge is not working. When I turn the key from off to on, but not running, I see all the little rpm lines light up all the way to redline. As I am starting the car I get a reading off about 800-1000, but the second the car starts running I get no reading at all.
What could be wrong? I would hate to spend a money on a dash if that't not the problem.
Old Apr 6, 2008 | 04:23 PM
ikeepitreelz's Avatar
Car: 1988 gta-
Engine: 383 tpi
Transmission: 700 r-4
Re: Digital Dash TACH not working
did you check the wires that go to the distributor. or
Old Apr 6, 2008 | 04:55 PM
SDalt404's Avatar
Car: 1988 GTA
The problem was the tach electronics in the cluster and the wiring harness that is attached to the back of the cluster. Replaced both of those and it works fine now.
Old Mar 16, 2013 | 01:05 AM
Cameronrw13's Avatar
Car: 1987 GTA
Axle/Gears: stock 3.27
I'm having kind of the same problems. Where did find those parts to replace?
The_Phoenix
Feb 4, 2016 07:10 AM
Sanjay
Aug 12, 2015 03:41 PM
marcusaw
Aug 10, 2015 08:13 AM
beachrodder
Aug 7, 2015 04:27 PM
stalkier
Aug 7, 2015 04:49 AM
