wiring headaches please help!!!
Old Apr 13, 2008 | 02:41 PM
hayabusa1257's Avatar
Car: 86 ta
Engine: 333
Axle/Gears: stock
Basic info
86 trans am
327 swap
I've looked over the site and I'm still confused about my starters wiring. Is this correct the big wire coming down from the postive battery goes on the main stud, as well as the three red ones. This gives me power to my lights turn signals etc... so were does the pink goI tried on the s terminal and fried two starters. The wires are all chopped up from the previous owner. Does purple go to s terminal? The guy I bought it from was starting it with just the bat wire and the reds all on the main stud and nothing else.
Old Apr 13, 2008 | 08:18 PM
sikZ28's Avatar
Car: 86 Trans Am
Re: wiring headaches please help!!!
Yes, the 3 red wires and the positive bat cable go onto the large stud and the purple wire goes onto the "s" terminal on the starter.
If it keeps burning up starters when you hook it up, then there is definately a problem with the hacked up wires.
As for the PO starting it up with just the wires on the main stud, I don't know how he was doing that...
Old Apr 13, 2008 | 08:28 PM
Car: 86 ta
Engine: 333
Axle/Gears: stock
Thanks that really helps me out turns out i was using the pink wire I thought i soder on the purple but it was pink, so that's what was burning it up ,now to just hunt down the purple.any suggestions were to start. I yeah i have no clue i've discovered some screwed up stuff.
Old Apr 13, 2008 | 08:43 PM
sikZ28's Avatar
Car: 86 Trans Am
It should be right down by the starter with the other 3 red ones.
You sure the pink wire isn't just a faded purple wire?
Old Apr 14, 2008 | 07:25 AM
Car: 86 ta
Engine: 333
Axle/Gears: stock
It's coming out of the harness so it could be but, then i don't know why I keep blowing up solenoids
I think i might need to just look at the messed up wires
Last edited by hayabusa1257; Apr 14, 2008 at 07:26 AM. Reason: Automerged Doublepost
Old Apr 14, 2008 | 09:37 AM
Ep1nephr1ne's Avatar
if you can get ahold of the all data print out they are very helpfull, gives the colors and full pin outs for any cars electrical system, all years, different setups, I used it to switch my 83 cross fire to a 91 TBI. it worked perfect although in the end i switch to a carb keeping my electronic spark control.
Old Apr 14, 2008 | 11:05 AM
Car: 86 ta
Engine: 333
Axle/Gears: stock
I have a haynes manual with all the diagrams, the po just cut and chopped wires so I have to sort througth his mess
If you know anything about thegrounds and the engine ground I could use some help with that too.
Last edited by hayabusa1257; Apr 14, 2008 at 11:08 AM. Reason: Automerged Doublepost
Old Apr 14, 2008 | 12:00 PM
sikZ28's Avatar
Car: 86 Trans Am
I don't really like the Haynes manuals. Seems like they dont have all the information that you need.
Here is a great link for 86 wiring...http://92b4crs.tripod.com/86wiring/86wiringindex.html
it is from a link that is on TGO homepage under technical artcles.
Check it out.
Old Apr 16, 2008 | 11:01 AM
Car: 86 ta
Engine: 333
Axle/Gears: stock
my autoshop class at school also has alldata
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
stalkier
Aug 21, 2015 01:54 AM
