Alternator Bad?
Old Apr 17, 2008 | 09:15 PM
CRUSHER's Avatar
Car: 88 Iroc
Engine: 350(300hp G.M crate, supercharged)
Alternator Bad?
Hi guys, here is the problem:
Battery guage is haunted(lol), will read belolw 12v somtimes. stays pegged between the 10v and 13v mark on the gauge then after driving around for a bit will jump back to normal 13v. Other times on initial start up will go to 13v then after driving around for a bit will get pegged again at 10v and 13v mark....Just put a new serpentine belt in the other day the old one was pretty cracked and worn, thought that might fix the problem...didnt thought... What gives???
any ideas..I have no heavy duty stereo system in it causing a huge load...Have a new Red top Optima battery in it also....
Old Apr 17, 2008 | 09:25 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Alternator Bad?
take it off and take it to an auto parts store to have it tested....
Old Apr 18, 2008 | 12:01 AM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: Alternator Bad?
might have a cell going bad
Old Apr 18, 2008 | 01:00 AM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
Re: Alternator Bad?
cluster could have a bad connection or i know its a motto with most of the gauges on third gens is that they arnt perscsion instruments, i would do as mentioned before and take it to an autoparts store and have it tested for free, assuming u drive your car at night do the headlights seem to dim when it drops. im gonna vote that its a guage issue not an alternator.
Old Apr 19, 2008 | 03:49 PM
CRUSHER's Avatar
Car: 88 Iroc
Re: Alternator Bad?
Hi Jeff, you were right it was the connection to the gauge....Did a little test, pulled out the gauge and connected a voltmeter to the terminals with the engine runnning...and it read 13.3 V...re-seated the gauge back in here and blamo reading correctly no pegging....battery terminals were reading 13 V with the engine running.....Thought my alternator was on its way out
Hotrodboba400
Dec 10, 2019 07:07 PM
92firebirdguy
Sep 1, 2016 07:53 AM
sahlomonic
Sep 20, 2015 07:15 PM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
