Electrical problem...
Old Apr 18, 2008 | 09:14 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
Well it was a long and anoying winter. I finally got around to firing up the transam. Sure enough the battery was dead so I put a charge on it, kicked it over and she started. After about 5 minutes of running I heard a snap near the battery and sure enough a wire that I am guessing is about 12 guage literally got so hot that it melted the shielding right off the wire. I am going to need to replace that wire for sure. I am assuming its the wire coming from the alternator to the battery but it runs in a real weird way. Anyone have the wiring diagram for this wire or for the electrical charging circuit so I know how to trace it back to make sure that this is the wire. I plan on upgrading it to 4 guage if possible when I make the required repairs
Old Apr 18, 2008 | 09:51 PM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
Re: Electrical problem...
could just run your own wire of a bit heavier gauge however you like, just goes to the port on the side of the alternator.
1992Z28!
Nov 19, 2015 07:33 AM
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
lanceflame44
Sep 25, 2015 12:28 PM
