no turn signal- cant locate flasher fuse
Old Apr 22, 2008 | 07:52 AM
mpb74's Avatar
Car: 1986 Iroc-Z
Engine: 355 Phase 2 Bowtie heads
Axle/Gears: 342
my turn signals are not working so i'm starting with the basics. i need to try changing out the flasher but i cant find it! where are these two fuses located?
Old Apr 22, 2008 | 11:37 AM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: no turn signal- cant locate flasher fuse
on the firebirds they are located in the convienenc center under the dash.
remove trim pannel you should see it.
Old Apr 22, 2008 | 11:44 AM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
well check the fuse but most likely the flasher is bad. Do they stay on or is there nothing? If they stay on bad flasher (big silver thing on fuse block) If nothing then replace fuse and trace down your problem.
Old Apr 22, 2008 | 11:47 AM
mpb74's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 342
i checked all of my fuses. my panel beneath the dash(drivers side) is missing. i have search every where for this convience center and i can not find it. is it on the drivers side or is it towards the center behind the stereo?
Old Apr 22, 2008 | 04:20 PM
enswrob's Avatar
Car: 89 Firebird
Axle/Gears: ?
ooh i forgot it flips down. big black looking box on right side of steering wheel under the dash.
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
Moore89
Aug 24, 2015 07:06 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
