fuel pump power wire 1989 5.7 tpi?
Old Apr 22, 2008 | 12:02 PM
89irocTPI's Avatar
Is the pink or tan/ white the power wire. Im trying to run a new power wire to the fuel pump that is wired to a toggle switch. Is it safe running a 12 gauge wire to that tiny factory power wire and waht is the factory fuel pump wire gauge?
Old Apr 22, 2008 | 01:57 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: fuel pump power wire 1989 5.7 tpi?
If you still have the factory harness, I'd recommend using the green/white wire on the fuel pump relay to activate the fuel pump.
Why do you need to run the fuel pump from a swich? Did you remove TPI and went to carb? Or is your TPI fuel system giving you trouble?
Lou
Old Apr 23, 2008 | 12:06 PM
89irocTPI's Avatar
its been carb now for about a year and i would like to get ride of the computer. I bought a jegs relay kit so i dont wanna mess with the factory relays
Old Oct 29, 2008 | 07:16 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
Did you ever get this working? I got rid of my computer and basically only have the power wire and wires for the guages in my engine compartment. I dont have any of the factory relays. I havent looked at any diagrams yet, but my interior is out and i was going to just see which wire got power when the key is on and wire a switch to that, the only problem with that is my relays are already out... so if you know what wire it is on the interior side, let me know.
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
