Where is the other end for our gauges ground?
Old Jun 6, 2008 | 06:08 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
where is the other end of our dash's ground?
i mean one end of the ground wire connects to our gauges where does the other end go?
chassis or engine block behind the cylinder/valve cover on the driver side???
i'm only asking because my gauges don't seem to be giving me teh right readings
they are aftermartket digital gauges and were fine but i just want to rule out a bad ground before i look eleswhere
everyrthign was working fine for months and now im reading 30 degrees higher than usual and im dont think its right.
my tach is slightly quirky at times meaning it will read fine but occasionally display some weird number or ----- for like a blink of an eye and then go back to normal operation
my oil pressure reads -1 to -3 with just ignition on when i already calibrated it to read zero before starting the car
just want to rule out a bad ground and i need to know where the gauges get there ground
thanks
BRoss99
Aug 10, 2025 05:08 PM
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
justin57
Aug 20, 2015 07:05 PM
