Lets play guess that connector....
Old Jun 15, 2008 | 08:11 AM
88TransAmFreak's Avatar
Car: 1971 Camaro
# 1. Not sure what this goes to, but it runs the lenght of the car towards the rear maybe? Looks like it's mountable with two screws and has three wires (black, pink, and tan/white stripe)
Fuel pump maybe?
# 2. Same as this one, it's near the drivers side of the dash close to the pin switch wiring, has three wires ( 10 guage orange/black stripe, 10 guage Pink, and a 16 guage orange)
I'm looking for the connector that the power window wiring plugs into.....any ideas?
Old Jun 15, 2008 | 08:24 AM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
Re: Lets play guess that connector....
Yep, the first one is your fuel pump connector, I'm not sure what the second one is.
Old Jun 15, 2008 | 09:54 AM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
second one is power supply for power windows,and plugs into a black connector above the drivers side kick panel
Old Jun 15, 2008 | 10:07 AM
Car: 1971 Camaro
That answers my questions.....Thanks so much!
Old Jun 15, 2008 | 11:29 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
T/AFreak, hope I can borrow your thread . Anyone know what this connector goes to? It's right above the drivers left foot.
Old Jun 15, 2008 | 11:42 AM
wvabreeze's Avatar
Car: 1988 convertible Z28 I think
Engine: 30 over 350 carbed and HEI
Transmission: T5 5speed
Axle/Gears: 9bolt 327posi disk brakes
If your car is a standard trans it looks like the plug that goes on the clutch pedal so you have to have the clutch pedal pushed in to start it.Mine was an auto and I jumped those together when I put the 5speed in it.I didn't have that plug under the dash but looks like the wires I jumped together.
Old Jun 15, 2008 | 11:51 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Mine is automatic.
Old Jun 16, 2008 | 02:06 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
I think you're right about that wire. They probably used the same wiring on both auto and manual cars. I found one more plug, maybe someone will know what it is. This one is next to the air filter and coolant jug. It has a black and a green wire.
Old Jun 16, 2008 | 02:20 PM
blackandgoldl69's Avatar
Car: 1984 camaro z28
Engine: L69 H.O
there should be a rubber hose running from your air pump up to a black box looking thing with a bunch of hoses running out of it that connector plugs into it. there should be two plugged into it one in the bottom and one in the side
Old Jun 16, 2008 | 02:59 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
This is the only thing that fit that description (I popped the cover off). I already has two plugs connected to it though.
Old Jun 16, 2008 | 03:50 PM
vette9190's Avatar
Car: 1991 Chevy Camaro RS
Transmission: 700R4,
Axle/Gears: 3.73 w/SLP Zexel Torsen Limited Sli
80schild
That looks like it is the wires for the VSS on a TBI car. I just swapped fromTBI toTPI on my car and the TBI cars use a VSS bufferbox. The wiring for this feeds in through the driversside bulkhead connector(C100) as the TPI cars go to the ECM throught the pass side wirning. just my
Old Jun 16, 2008 | 10:20 PM
Engine: L69 H.O
woops sorry didnt realize your car isnt carbed im an idiot your connectors are different on your setup sorry for the miss information
Linson
Oct 24, 2025 02:00 PM
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
rusty vango
Sep 29, 2015 02:44 PM
