Where does the fuel pump wire run?
Old Jun 18, 2008 | 08:42 PM
George90GTA's Avatar
Car: 1990 GTA
Engine: 355
The gray wire from the relay, the gray wire from the oil pressure relay and the ECM wire merge somewhere.
I need to splice into the wiring after the merge. I looked by my ECM and got lost. I now am thinking its under the door sill or down the tunnel.
Help please, Thanks.
Geo.
Old Jun 18, 2008 | 09:00 PM
Pop45398's Avatar
Car: '91 RS
Engine: 355 on a stand
Axle/Gears: 3:42
Re: Where does the fuel pump wire run?
As I said in your previous thread, it's inside the wiring harness as it crosses the firewall, between the relay and where it passes thru the firewall on the passenger side. If you access it inside the passenger compartment next to the ECM you will be downstream of the splice.
Old Jun 19, 2008 | 04:58 AM
Car: 1990 GTA
Engine: 355
Thanks for the info.
I thought there would be an easier way to chase it down. I have been searching by the ECM as you stated and it seems daunting. at some point it should be easier to find.
Old Jun 19, 2008 | 08:42 PM
Car: 1990 GTA
Engine: 355
I thought I found it but no go. I stopped checking with the Macgyver(sp) technique! Too many butt connectors!
I believe it splits inside the engine compartment behind the engine and runs down the tunnel.
HELP!
Old Jun 20, 2008 | 09:40 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
That wire is nowhere near the ECM.
It runs from the engine compartment through the C100 bulkhead connector and then down the DRIVER side, by the door under the carpet, then crosses under the rear seat into the middle of the car, up the back and into a plastic through-connector C313 just behind the back seat.
Hope this helps.
Lou
Old Jun 20, 2008 | 10:43 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Exactly
The wire is grey.
Old Jun 20, 2008 | 12:38 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Geo.
Why does it matter where you splice in? If all the wires are connected, then they are all connected. You should be able to tap in anywhere.
Old Jun 20, 2008 | 01:10 PM
BigBadLou's Avatar
Engine: TPI
George didn't mean "splice" per se. He wants to interrupt the fuel pump wire and put a switch on it. He has another thread about that.
But you're absolutely right, to "tap into" a wire, it doesn't normally matter where.
Lou
Old Jun 20, 2008 | 02:28 PM
Car: 1990 GTA
Engine: 355
Thanks for your help!!!!
Another happy customer!
RazorN8
Jan 7, 2022 11:44 AM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
