weird digtial dash electrical issue please read
Old Jun 29, 2008 | 08:32 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
i have a 1986 trans am i installed a after market digital dash for all the gauges
i noticed while driving at night my temp reading on my digtial aftermarket dash is like 20-30degrees higher than normal
i realized that the temp reads higher with my headlights on and instantly drops with the headlight switch off and rises instantly with headlight switch on
i would play with the switch on and off and watch the temp just drop or climb with whatever position the switch was in
the wiring is exactly the same that was used with the original dial/meter gauges
using the same wires i did nothing custom.
what could be causing this?
Old Jun 30, 2008 | 01:18 PM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
Re: weird digtial dash electrical issue please read
Sounds to me like it could be a wiring problem with your digital dash. Install the original cluster for a test and see if it has the same problem.
Old Jun 30, 2008 | 01:48 PM
Bobby_80s's Avatar
Axle/Gears: no idea
well it just seems totally weird
maybe the temp wire to the gauge is shorted or connected to where those in dash light bulbs used to be so your dash lights up when your driving at night and have headlights up?
the manual had me remove the bolts but maybe somehow makign contct with the copper paper circuit board on the back?
Old Jun 30, 2008 | 02:14 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
The temp gauge by readint resistance to ground. Somehow the resistance to ground of the sender wire changes when the lights are on..
Ghettobird52
Jul 5, 2024 11:18 PM
Jorlain
Aug 24, 2022 05:11 PM
Wesly_66
Aug 26, 2015 09:55 PM
lakeffect2
Aug 23, 2015 08:44 AM
mizz0313
Aug 12, 2015 06:45 AM
