MSD 6BTM box affect the boost, how to change it
Old Jul 1, 2008 | 04:59 PM
tuulepoiss's Avatar
Car: Pontiac Trans AM GTA '88
Transmission: th700-r4
Axle/Gears: 3,27
Hello
I bought 88 GTA which has a 355 engine with blown pistons, headers, RAM air inlet, ATI Procharger P-1sc, MSD 6BTM fire box.
Boost clock shows only 5 PSI when the gas pedal is on the groud. Visual pipe leaks dont see beetween procharger to Ram air but somewhere the boost goes away.
During factory data smaller pulley form procharger should give out 12 PSI. I have installed smaller 85 mm pulley.
Where i shoud start sheck the problem?
I thought that is there any change that MSD 6 BTM firebox controll the boost and dont allow more than 5 psi because it is changed previus owner.
I have seen on JEGS catalog that togheter with MSD 6 BTM box olso must be some controller ( dashborad mounting) where can be turn ingnition later 1 degree untill 15 degrees and all this are controlled thrue the current boost.
In my car i didnt find the control unit. Can be like that the controller is removed and the most lower setup controls the boost?
People who have experience with 6BTM fire box i wait your comments.
9192camaro
16
Feb 3, 2019 12:21 AM
toronto formula
Nov 10, 2015 06:17 AM
1992Vortec
Aug 31, 2015 08:05 PM
overdriv
Aug 20, 2015 03:52 PM
midias
Aug 15, 2015 05:07 PM
