ERROR CODE 53
Old Jul 13, 2008 | 05:46 PM
3rdGenSkan's Avatar
Car: 90 camaro rs
Engine: LO3 305 tbi
Axle/Gears: 3.42 posi
ERROR CODE 53
hi i have a 1990 camaro rs v8 305 and recently while driving ive been getting the service engine soon light soon. i checked out the codes using the paper clip trick and my car came back with a error code 53. whats the next step i should take investigating the issue?
Old Jul 13, 2008 | 06:39 PM
Guy In A 90 RS's Avatar
Car: 1990 Camaro RS
Engine: 3.1 V6 MFI
Transmission: MD8 Hydra-Matic 4L60
Axle/Gears: Standard/3.23
Re: ERROR CODE 53
Well, I'm taking this directly from the 1990 Chevrolet Service Manual:
Code 53: System Over Voltage
This code indicates there is a basic generator problem.
Code 53 will set, if voltage at ECM ignition input pin is greater than 17.1 volts for 2 seconds.
Check and repair charging system.
I'd say have your alternator checked out. And wires too. Just a starting point. Hope this helps.
Old Jul 13, 2008 | 06:49 PM
3rdGenSkan's Avatar
Car: 90 camaro rs
Engine: LO3 305 tbi
Re: ERROR CODE 53
What's included in the charing system?
Old Sep 3, 2008 | 10:44 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: ERROR CODE 53
Battery, Alternator,
Like the guy above said, its probably your alternator, was with my 53
Old Oct 24, 2008 | 12:04 PM
Daves03's Avatar
Car: 1991 Chevrolet Camaro RS Red
Engine: 305 V8 TBI
Transmission: TH-700R4
Re: ERROR CODE 53
probably the alternator voltage regulator if you know how to rebuild your alternator you can get off pretty cheap.
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
3rdgenparts
Sep 28, 2015 10:47 PM
mfp189
Sep 27, 2015 09:25 AM
