vats fixed still interminnet start
Old Jul 17, 2008 | 04:50 PM
carmodder's Avatar
Car: 92 rs ,2000 a6 2.7t
Engine: 355 carbed,twin turbo v6
sorry for the long explanation but i want to get it all in
soo ive been having problems with the vats system and it ended up being a broken wire to the lock cylinder so i fixed that and over the passed week its been giving me trouble again not wanting to start but if i walk away for a half hour or so and come back most of the time it would start.security light would not go off so i knew it was vats related. today its all screwd up very hot day today went to go to work this morning and no start so i walk a way for a few come back a wala its starts got to work, go to leave no start again security lite on after a few it finally starts while on the highway she dies pull off the highway and try to start her back up and nothing but this time the security light turns off after 5 sec but still not starting cranked it a few times and it would start to crank for like a sec then stop but then it started after a few tries died again few seconds down the road but started right back up got it home shut it off ..but it wont turn back on again ..wtf electrical gremlins,ecu ? oh and the vats connector under the dash reads the correct ohms with the key in the ignition?
Old Jul 18, 2008 | 06:35 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: vats fixed still interminnet start
When the car died on the freeway, that doesn't sound vats related at all. I would guess that your ignition module is either on its way out or is in fact out.
It sounds to me like since it was such a hot day out plus the engine heat cooked the ign. module to keep it from spinning freely. The heat also effected the starter creating a minor hot start issue. This is just a guess based on what you wrote.
Have you checked to see if your getting spark while cranking? I would start there as I have a hunch it is the ignition module.
Old Jul 18, 2008 | 01:51 PM
carmodder's Avatar
im not to worried about the stalling as much as the not starting part but..wouldent the starter still click or crank even if its not geting spark..the car does not crank so therefore it will not spark correct or no ? or does the module tell it to to spark?
Old Jul 18, 2008 | 02:21 PM
carmodder's Avatar
went out today to do some trouble shooting but she started how am i suppose to trouble shoot when it works? it was also hot today but the car was not it the direct sun today started right up 3 times in a row was looking under the dash today for the starter enable relay and found a plug where a relay was suppose to be but not in it. it has a green brown blue and yellow wires going to it ti that the enable relay?
Old Jul 19, 2008 | 01:36 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
I'm sorry I must have misunderstood, I didn't realise the starter wasn't doing anything. If the security light isn't staying illuminated then it isn't vats related. Maybe the starter is on its way out, the next time it doesn't do anything and the security light isn't illuminated try hitting the starter with a hammer and if it works you can bet the starter is bad.
As for the wires you found, I'm looking at a wiring diagram for a 92. There should be a black/yellow wire from the pass decoder box to the start enable relay. Also a dark green wire from the gear selector switch. to the relay.
Old Jul 19, 2008 | 01:57 PM
carmodder's Avatar
im thinking it might be a heat soaked starter thats why it wouldent start the second time as for the first time idk. the car does have headers so im going to relocate the starter selonoid and replace the ignition module and the ignition coil hopefully that helps
Old Jul 19, 2008 | 04:17 PM
carmodder's Avatar
ok so i replaced the ignition module and the ignition coil car ran smoother with a nice idle didnt stall but didnt drive her hard either but fgot home at bam wont start again so i jump the starter and bam she starts right up shut off let sit for 10 mins and she starts fine with the key again.. so im gonna relocate the starter selonoid and hope thats all she wrote
Old Jul 20, 2008 | 01:55 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
that's good, looks like you figured it out. I was going to do the remote solenoid myself back when I was having the same issues, but didn't like the extra wires and everything so I went with a LT1 starter (considerably smaller) and no hot start issues ever again.
Old Jul 20, 2008 | 03:46 PM
carmodder's Avatar
so i put in a remote selonoid from a tbi mustang part #f492 $10 from the parts store a new battery cable and a push button didnt have any extra wires still the same with the other selonoid just routed to a different place. the car still doesnt like to start with a key when its hot out but starts fine with the button. the car was still stalling but i found a dry rotted hose that goes to the egr valve and some other thing and fixed that. also i advanced the timing 2* and so far its been running fine ..ill keep updated
Glowsock
Jul 24, 2025 03:15 PM
theshackle
Mar 5, 2017 06:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Jae992
Aug 27, 2015 09:07 AM
